Hello i have a Corsair c70 case and i am am looking to upgrade all the fans in the cast along with my h100i v2 that is 7 fans in total. What fans should i get? i don't need rbg and and help to set up airflow would be nice with the reconfig.
also sorry to the mods if this is in the wrong sub-form
https://linustechtips.com/topic/1010572-upgrading-case-fans/
What are your specs and what fans are you currently using? Why do you want new fans?
https://linustechtips.com/topic/1010572-upgrading-case-fans/#findComment-12100919
What are you looking to achieve with this upgrade? Better Cooling? Lower Noise Levels? Both?
Also specs of your system would be helpful, for example if your GPU is a blower style card that can change things quite a bit.
As for your configuration I don't think installing all 7 fans is worth the money or noise, 2 intakes on the front and 1 rear exhaust is usually plenty (ignoring radiator).
Although the side panel fans can be helpful for cooling your VRMs and your GPU I think installing 2 side panel fans provides little benefit over 1.
Whichever route you go I'd recommend going with Noctua fans.
Noctua Low Noise
Radiator Fans: Noctua NF-F12 PWM
Case Fans: Noctua NF-P12
If you don't give a damn about noise then these will push move a good amount of air. You can get a 3000rpm variant as well but that's a little overkill outside a server.
You can also control them with PWM so they're not shrieking 24/7.
Noctua High Airflow
Radiator + Case: Noctua NF-F12 iPPC 2000 PWM
I'd recommend a positive pressure configuration: 2 x front intakes, 2 x top intakes (radiator), 1 x side intake (Upper). 1 x Rear Exhaust.
This will reduce dust build up immensely, not sure if it's the optimal configuration, you'd have to do some testing yourself and see.
Also if you're interested in controlling the fans more accurately I'd recommend a Corsair Commander Pro it does a pretty good job even if the software is pretty garbage, just avoid iCUE and use LINK.
- Personal Rig -
AMD 7950X3D / 64GB G.SKILL DDR5-6000 EXPO / ASUS RTX 4090 TUF OC
ASUS ProArt X670E / Noctua NH-D15 Corsair 4000D Airflow / Corsair RM1000x / 4 x 2TB Crucial P5 Plus
- 🪦 HW Graveyard 🪦-
MSI GTX 780 Lightning 3GB 🪦🫡 Dec 2013 - Dec 2018
Seasonic Platinum 1000W 🪦🫡 Dec 2013 - Dec 2018
PNY GTX 470 1280MB 🪦🫡 June 2010 - August 2017
Intel Q9550 / Q9450 Systems 🪦🫡 Q1-2008 - Q3-2016
- Desktop Audio Equipment -
ADAM Audio F7's | Topping D30 Pro | Topping A30 Pro | HD598 & HD6XX w/ Sheepskin Pads
https://linustechtips.com/topic/1010572-upgrading-case-fans/#findComment-12100956
Noise ain't a problem for me so better cooling overall I have a Vega 64 rog strix for GPU my current set up is two intakes front plus one on hard drive case so it pull arcoss them and then one exhaust back and then exhaust from rad pushing
And one intake and exhaust on the side
for the rad i have stock fans otherwise i have 5 Corsair ML120 i am looking for better cooling
https://linustechtips.com/topic/1010572-upgrading-case-fans/#findComment-12101036
What are your temps? The stock SP12L's on the H100i V2 already perform very well. There isn't much point in replacing them other than to lower noise.
Did you mean that you already have ML's or are you just considering them?
https://linustechtips.com/topic/1010572-upgrading-case-fans/#findComment-12106241
1 hour ago, ears_ears said:
Noctua case fans are overpriced Arctic fans that also look like crap.
Yes, they perform similarly but there's differences.
The build quality is better on Noctuas (after all it's part of why they are so well known) and their customer service is pretty nice as well. When my brother had to RMA his cooler they were pretty friendly about it.
About the design thing, they have this thing called "Noctua Chromax" now, which surprisingly looks decent. Their classic 'beige and brown' retirement home-esque design makes me want to vomit, but this Chromax stuff looks alright.
I'd like to know where you got the 'overpriced Arctic fans' thing from though, I'm genuinely interested.
https://linustechtips.com/topic/1010572-upgrading-case-fans/#findComment-12107056
