Applying thermal paste on square-bottom cooler
TimidMage66
Got a Gammaxx 200T for my Ryzen 5 2600, but confused how you apply thermal paste due to the square design on the bottom
On Intel processors I thought you get the thermal paste and only put a pea sized blob on, and it would spread out as you put it on. However, due to the square bottom design of my cooler, I feel like doing it this way would not cover the entire surface area. It already has some pre applied, but I got some noctua paste I want to use.
What is the proper way to apply thermal paste in this situation? Do you need to use a card to spread it out manually?
99% of coolers have square plates. Your CPU is a square/rectangle too...
Just put a pea-sized blob on, it'll spread out over most of it. If you're really worried then spread a thin layer over your CPU with a credit card or something.
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
Everything you need to know about thermal paste is in here.
There are lots of methods for applying it, but this video has it backed up with numbers.
No signature found
This applies to practically every CPU and cooler (square bottomed coolers, square CPU).
Just add a line or a pea-sized blob of thermal paste onto the top of your CPU. I have no preference as to what method you use since they deliver the same performance.
Just as you have always done it. Its not rocket science. If it would be TR or Intels workstation chip, then elongated rice grain might suit better.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
