Hi, I have tried to make a build for my next gaming pc but I definitely need some help. I have chosen to go with an intel i5 8600k, I will not be overclocking right now but I will have to. I’ll use a Gtx 1070 8gb from Asus ( in Amazon Italy its only 400 ) and a moba always from asus. Please I need some help to figure out if I can use a 3000mhz even though Asus says it supports 4000mhz and if the whole build can work. I would also like to know if I have to buy any SATA or power cable extra. I already have an ssd and an hdd, should I consider buying an m.2 storage?
CPU https://www.amazon.com/Intel-i5-8600K-Desktop-Processor-unlocked/dp/B0759FKH8K
GPU https://www.amazon.com/GeForce-Dual-Fan-Gaming-Graphics-DUAL-GTX1070-8G/dp/B01JHQSZ5Y
MoBa https://www.amazon.com/Prime-Z390-Motherboard-LGA1151-Gigabit/dp/B07HCY7K9L
PSU https://www.amazon.com/d/Computer-Power-Supplies/CORSAIR-TX650M-Certified-Modular-Supply/B01N18J52E
RAM https://www.amazon.com/Patriot-Memory-3000MHz-Channel-PV48G300C6K/dp/B0157UPYZ8
CASE https://www.amazon.com/Cooler-Master-MasterBox-Mid-Tower-MCY-B5P2-KWGN-01/dp/B075N132C7
COOLER https://www.amazon.com/Cooler-Master-RR-212S-20PC-R1-Direct-Contact/dp/B07H22TC1N
Do you think I need extra fans? And how can I make it more rgb? Thanks a lot for your help and forgive me for grammatical errors.
https://linustechtips.com/topic/1009943-first-gaming-build-need-help-please/
Oh god this is why people get fucked over buying the maximus xi hero. The aorus elite z390 board from gigaabyte is much better for overclocking.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
You don't need 3000mhz ram for Intel CPU's, 2400 is fine at a minimum IMO. For $40 I think the cryorig h7 is a better aircooler, though I could be wrong.
8086k
aorus pro z390
evga 3070 ultra
Just now, Andrimega said:
Is the price the same?
yeah its about the same in the US. Can you make a pcpartpicker list so this is easier to work with?
8086k
aorus pro z390
evga 3070 ultra
also, get a case with better airflow. If you're overclocking somewhat high you'll obviously want a better cooler.
8086k
aorus pro z390
evga 3070 ultra
tried to have a theme
all white/black components
cpu cooler ram and gpu all have rgb
all fans are same brand and have rgb(since you wanted rgb)
1070ti instead of 1070
nzxt board has beefy vram and clean look
case has godly airflow
Bless you ??
I would take a look at the Phanteks P350X as a case, if you like the look of it. Great value as it's cheaper than the H500P, quite a bit of character, and plenty of airflow.
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
