Hey guys, so I have a z370-i strix mobo that has a 4 pin pump fan header that runs at 100% by design. I want to slow the pump down a little for noise and longevity but the other 2 headers are being used by 6x 140mm fans. My question is can I put a Noctua PWM low noise adapter on the pump? Would that cause any damage to the pump?
(Using EKWB PWM pump res combo)
Thanks!
https://linustechtips.com/topic/1008234-ekwb-pump-res-controlling/
Don’t see why the aio speed can’t be lowered.
The adadter could work.
Or double a fan or two and use a fan header. Or get a hub and free up more.
9 minutes ago, Jimmywayne said:
Yes, but remeber that you can also change the speed of that pump header by changing the aio control in BIOS.
So change it in the software.
Which is the correct thing to do. Assuming you want the system to protect itself if the pump were to fail.
