Thanks for the reply. I really don't know what you guys need to help me, so I haven't shared much.
Anyway, I have two individual ISP's, going into each of their own modems, then the two modems are attached on another router. Usually to check the second ISP's speed, I just shutdown the power of the first ISP.
But I wanna know if there is a way to check the secondary ISP without shutting down the first one. Cause if I shut down the first ISP, there's a bit of a downtime, and I am more or less hosting something over the net, which proves difficult to the client if I do it every time.
That is a good idea, but not one that I can apply on my end. They are set up on a server rack, I guess I can bring in a laptop for a last resort.
But what I really want is a software way where I can, I don't know probably run the software directly on the server attached to it. Are you familiar with PfSense?
Now that I think about it, is there a way to check specific ports using PfSense?
Well, you could always try logging into your router and just disabling whatever port the primary is plugged into and running a speedtest, then re-enable it after you're through. I'm assuming you're using a buisness class router that should have that feature in it.
And I'm not familiar with PFsense, is that what you're using as a router?
I think doing that would slow down the total bandwidth of the network (or cripple it) since it is set up that if ISP A goes down B would take care of it, but B is more of the less known ISP, so it's more of "at least it's running" kind of set up for B.
On PfSense yes and no. We are running on a MikroTik router as a main, and PfSense is more of firewall/router together with another software called Fail2ban running on another machine. Anyway it's a really a simple setup.
I just want to know of there is a software way (or remote way) to check secondary ISP without disconnecting primary and causing down time. Really thank you (and other people) for the inputs appreciate it.
