Meshify C sound?
Solved by _Hustler_One_,
3 hours ago, LeoNido said:Does the Meshify C leek a lot of sound/noise?
You might want to check this video. A high airflow case vs a quiet case, but the airflow case still can get better air flow when it set to quiet mode at same decibel level. You might get it to be noisier to get the best airflow. But if you want it to be as quiet as a quiet case, the airflow case still will get better airflow..
Featured Topics
WolfOfValhalla ·
Posted in Cooling0 -
FireLegend ·
Posted in Troubleshooting3 -
2
1
6
UnRaidLegends ·
Posted in Laptops and Pre-Built Systems0 -
3
7
2
