Graphics Card Upgrade Advice
Go to solution Solved by mgsstar,
I did not get any replacement as retail guy did not have any. He offered me a refund instead.
Since I bought all other components & connectors, my requirement now are that the card should not be longer than 6.5 inches at the base and should have 1 full size display port out, 1 HDMI out and 1 DVI out. It should support AMD Eyefinity for running triple monitors and should run in a PC with 450w PSU.
I am looking at the below possibilities:
  1. Asus AMD/ATI HD 7750 1 GB GDDR5,
  2. MSI AMD/ATI R7 260X 2GD5 OC 2 GB GDDR5,
  3. Sapphire AMD/ATI FirePro V4800 1 GB GDDR5,
  4. XFX R7 260X 2 GB DDR5,
  5. SAPPHIRE 100367L Radeon R7 250X 1GB 128-Bit GDDR5,
  6. SAPPHIRE 100368DP Radeon R7 250 1GB 128-Bit GDDR5.
Am I in the right path? Cost does not matter. It just should work in the intel core2 duo machine.
I would just get the cheapest one here because you are only using it for video viewing. Not sure if you should get a Firepro card as you are just using it for video and not as a workstation (need someone to help with this). Just check that the graphic card that you choose has your outputs that you need and you are good.
I have a Lenovo Machine (Similar to this) with Intel G41 Express Chipset.
I need to connect 1 HDMI projector, 1 HDMI TV and 1 monitor.
I will be using triple monitor setup.
I previously posted on a wrong section of LTT Forums (New Builds) and still got useful advice that I do not need a card with 2 HDMI outs and that I can use a DVI to HDMI adapter.
If I can convert DVI to HDMI, what GPU will suite best for me? I need 3 1080p outs, No fancy gaming. Just HD video playback, presentations, demonstrations, etc.
I'm adding a picture of the motherboard:
Binoj D
https://linustechtips.com/topic/100663-graphics-card-upgrade-advice/
My good sir, you should really clean out your PC.
EWWWWW
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
What power supply does it have? most people on here (im guessing here) dont run 3 monitors for slideshows/presentations, its usually either 1 big screen gamign or 3 smaller screens gaming so you're likely to get responces like a nvidia gt610/amd 6450 which is super low end and others saying 7750ish which is entry level gaming...
im not 100% how demanding something like this will be but I dont think youll go far wrong with something like a 7750, it should have ample power for what you need and amds eyefinity is said to be really well sorted. and it doesnt require additional power so as long as you have a reliable 400ish watt power supply you should be sorted.
id look for one with a good cooler regardless, if your in india (wild stab in the dark) the cooler you keep the card the longer it should last.
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
Thanks. The computer lives in an air conditioned room. And I wont be using it 24x7. So I guess cooling is not an issue?
I'm thinking about this http://www.flipkart.com/xfx-r7750-core-2-gb-ddr3-graphics-card/p/itmdruhvpsjhecnk?pid=GRCDNCC9YZGMGE2F&otracker=from-search&srno=t_8&query=7750&ref=b98ebeeb-fb1b-4d36-8c0d-3bdea50fdc57
The card's product page says it is PCI 3.0 x16. I am not sure if it will work in my system. I can find an 450w PSU, btw.
Binoj D
pcie1, 1.1, 2.0, 3.0 etc are all interchangable, the maximum bandwidth changes but it wont be a problem (you can run a 7970 in a pcie1 board and you might only lose 5%)
that card should be fine (i had a look on that site too, a 7770 is around 25% more expensive..)
bear in mind i have not tried this so I could be wrong, I would wait for a few more replys or google around and see what others have done, always make sure your PSU is by a good well regarded brand regardless of power, not just some grey tin can with cables coming out of it....if it goes it could take the whole pc with it!
might be worth checking the "monitors, projectors" part of the forum (use google) and seeing what others have done, good luck and report back when you find out for sure in case someone in the future has the same problem. B)
Disgusting.
Based on what I can see, you might need a new PSU anyways to so you will have some PCIE power connectors. Most prebuilt computers don't have them, they just use basic PSU's
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130840
This card should work for what you're needing, don't really know your budget though
Main Rig CPU: AMD Ryzen 7 5700x GPU: Asus TUF Gaming RTX 3080 OC MBASUS AM4 TUF Gaming X570-Plus RAM: 64GB Corsair Dominator Platinum 3200 CPU Cooler: Cooler Master Master Liquid LC240E SSD: Crucial 250gb M.2 + Crucial 500gb SSD + 4TB Crucial SSD HDD:None PSU: Thermaltake Toughpower Gran RGB 850W 80+ Gold Case: Corsair Carbide 275R KB: Glorious GMMK 85% MOUSE: Razer Naga Trinity HEADSET: Go XLR with Shure SM7B mic and beyerdynamic DT 990
unRAID Plex Server CPU: Intel i7 6700 GPU: Nvidia Quadro P2000 MB: Asus B150M-C RAM: Crucial Ballistix 32gb DDR4 3000MT/s CPU Cooler: Stock Intel SSD: Western Digital 500GB Red HDD: 4TB Seagate Baracude 3x 4TB Seagate Ironwolf PSU: EVGA BT 80+ Bronze 450W Case: Cooler Master HAF XB EVO KB: Cheap Logitech KB + Mouse combo
Dude, what are you talking about? 2d graphics aren't demanding at all and your gpu won't ever get hotter than 40c on idle even in 30c ambient. To op, get the cheapest card you can find with 3 dvi/hdmi outputs and you'll be more than fine. for hd playback, I've seen a pentium 4 with built in graphics work perfectly. So even something like a gtx610 is more than adequate.
Finally my Santa hat doesn't look out of place
might be worth a mention to mr 650ti and 270x up there aswell then, i wasnt sure but atleast im not recommending a new powersupply for the sake of a 6pin pcie :D
fwiw my 7770 peaks 9and drops and peaks an drops) from 1%-15% watching a 1080p movie, i based my guesstimate on this, thanks by the way its good to know.
Yeah, video barely loads the gpu at all. keep in mind that your 7770 also has to do other tasks besides the video, hence why its usage can go up to 15% at times. The cpu is much more important in playing back video because it has to decode the movie you are watching. Keep in mind that my 3 year old htc sensation has no difficulty playing 1080p movies. :)
  • 1 month later...
I finally bought Corsair 450w PSU, XFX R7750 card.
The card did not output anything once connected. I configured bios to take onboard graphics as default and went to device manager, the card was not listed.
I then tried the card with a Lenovo M72e http://shopap.lenovo.com/in/en/desktops/thinkcentre/m-series-towers/m72e/ PC.
Same issue, display did not work from BIOS. I forced default to Integrated Display. But this time unknown VGA was present in Device Manager. I installed drivers from included CD. Catalyst did not start up. Then, I installed latest drivers from AMD's site, card gets detected as AMD Radeon HD 7700 Series. But still it is not outputting anything & I can't detect other cards other than Onboard Video.
GPUz Screenshot:
Card DOA?
Binoj D
If you're not into gaming, but into Movie Play Back and stuff, I would suggest a Radeon 7750 or a R7 250.
PC Build
AMD FX 4130@3.8GHz | Sapphire Radeon HD R9 290@947 MHz | 8GB of DDR3 1333MHz RAM | 500GB Seagate HDD | [broken] Cooler Master i600 PSU | Some LG Disk Drive that costed me $20|
GPUz Screenshot:
Card DOA?
Am I having an DOA card? How do I verify that? If its DOA, must replace it with vendor in 30 days. Already 5 days over :(
Binoj D
Did you try a different display output? I think the card is messed up as it has 4294967295MB of Vram or your drivers are making this error...
I would try this card on another computer before RMAing to make sure that it is DOA but I think its pretty messed up with 0 gpu clock, 0 pixel/vertex shaders. Try to see if your card has a bios switch beside the crossfire fingers or power connector and try to switch the bios.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
I tried HDMI and both DVIs. Tired in different PCs (Both are lenovos. But one is Core2Duo, other is i5) Tried installing new OS in the system with the card insalled (Win 7 installation took sooo long to complete with the card installed. Yet the card did not show up in device manager).
Binoj D
So the card worked when it was installing Windows 7? Tried installing AMD Catalyst drivers on it after you installed your OS (if it boots with it) to see if it detects it?
No. I had to use integrated graphics as default to install Windows 7. AMD Catalyst says that it could not find any compatible cards. However in the i5 machine, it detected the card. But I had these strange values in GPUz.
Binoj D
I would then recommend you to RMA it and you can your your igpu for now while your gpu is being RMAed.
