4 minutes ago, rdcdt said:
i think the fastest so pcie ?
What is your budget for a wireless card?
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
https://linustechtips.com/topic/1006553-wifi-card/#findComment-12064082
not really. The antennas are bigger, so the range is better most of the times, but if you're really close to the router, that doesn't make sense either. speedwise you should probebly get wireless b/g/n/ac or wifi 5
https://linustechtips.com/topic/1006553-wifi-card/#findComment-12064087
3 minutes ago, LukeSavenije said:
150 bucks for a wifi card? you can get one for 20 bucks on usb. and a good one too
USB wifi cards suck compared to a high end PCIe one.
Which still sucks compared to an ethernet cable.
https://linustechtips.com/topic/1006553-wifi-card/#findComment-12064102
i need a good range :)
thank you for helping
https://linustechtips.com/topic/1006553-wifi-card/#findComment-12064132
If you only need wifi and dont need bluetooth, then i have this wifi card:
https://www.amazon.com/TP-Link-Archer-T6E-Wireless-Technology/dp/B016K0896K/ref=sr_1_3?ie=UTF8&qid=1544457288&sr=8-3&keywords=wifi+card+pcie
It looks good and has 5gz, but no bluetooth is letdown.
I only see your reply if you @ me.
https://linustechtips.com/topic/1006553-wifi-card/#findComment-12064135
