Tell wget not to go outside of current webpage
Solved by INSERTNAMEHERE,
Right about now I would start some trial and error
Its curious why it doesn't really take all the pictures needed to create the webpage you are in.
there is also: '--regex-type=TYPE regex type (posix|pcre)'
To switch the regex type to pcre then you can use regexr for help and maybe the --reject-regex option.
Another Edit: you will definitely need -D to restrain spanning hosts in your example it would be both your page
boards.4channel.org/... and the i.4cdn.org/... hosts that should be on the list in this case
More info here:
https://www.gnu.org/software/wget/manual/wget.html#Spanning-Hosts
