So im building a pc for architectural 3d modelling (Rhino 3D, Revit) and rendering (vray), but ill also be using it as a gaming pc.
Tossing up between the Intel core i7 9700K and the Ryzen 7 2700X. Any suggestions? is it worth paying the extra for intel plus the third party cpu cooling?
https://linustechtips.com/topic/1004693-help-me-choose-a-cpu/
2700x over the 9700k is a small sacrifice and much better bang for your buck. The 9700k will definitely give you a slight increase performance in AC type softwares but its ultimately up to you.
If budget doesnt matter, go with the Intel chip and get a nice noctua cooler.
https://linustechtips.com/topic/1004693-help-me-choose-a-cpu/#findComment-12047777
I've heard the Ryzen 7 2700X is good at rendering it's also at a better price compared to the intel i7-9700k.
Current Pc Parts:
-CPU: Intel i7-9700k
-GPU: EVGA RTX 2070 black edition
-CPU Cooler: NZXT Kraken x62
-Mobo: Asus z390-E gaming
-Ram: Corsair Vengeance RGB pro 32g @3000MHz
-Storage: Samsung 850evo 256Gb
-Storage: Toshiba 1Tb 7200rpm
-Case: NZXT H500
-Extra: NZXT Hue 2
https://linustechtips.com/topic/1004693-help-me-choose-a-cpu/#findComment-12047780
Looking up Rhino 3D and Revit PC req I would rather choose the Ryzen 7 2700x.
To be an expert is to know more about less.
  • 2014 Build --> FX 8350 4.7GHz {} ASRock Fatal1ty 990FX Killer {} Reference GTX 980 4GB {} 2x4GB 1866MHz HyperX {} Seagate 2TB 7200rpm {} 840 EVO 120GB {} XFX PRO850W {} Noctua NH D14 {} Fractal Define R4 White Windowed
  • 2018 Build --> Ryzen 7 2700X {} ASRock Fatal1ty X470 Gaming K4 {} Gigabyte RTX 2070 8GB {} 2x8GB HX Fury 3200MHz {} Toshiba P300 2TB {} Kingston 480GB A1000 {} Corsair RM750W {} Enermax LIQMAX II 240 {} Fractal Focus G
  • 2021 Build --> Ryzen 9 5900X {} ASUS ROG Strix X570-F GAMING {} ASUS GeForce RTX 3080Ti ROG STRIX OC {} Gigabyte AORUS RGB DDR4 32GB {} Kingston KC2500 M.2 2280 NVMe 2TB {} Seasonic FOCUS GX-1000 {} ASUS ROG Ryujin 240 AIO {} NYXT H710i
  • 2026 Build --> Ryzen 9 9950X3D {} ASUS ROG CROSSHAIR X870E HERO {} ASUS GeForce RTX 5090 32GB ASTRAL LC {} G.Skill TridentZ Royal Neo RGB Silver DDR5 CL28 6000MHz 2x16GB {} Samsung SSD 4TB 9100 PRO M.2 {} Seasonic 1600W PRIME TX Noctua Edition {} Fractal Lumen S36 V2 RGB 360mm AIO {} Fractal Design North XL Charcoal
https://linustechtips.com/topic/1004693-help-me-choose-a-cpu/#findComment-12047789
