help me! my mic sounds bad idk why
Solved by ParkerWWW,
if you right click on the volume or speaker icon in the bottom right of windows 10, right click on it and hit sounds, then go to the recording tab, right click on your mic and go to properties. This will go to the window to make adjustments to your microphone like level, sampling rate etc.
Featured Topics
Emmanuel Katto ·
Posted in Peripherals0 -
1
2
Rusty Proto ·
4
WildOne ·
Posted in New Builds and Planning1 -
solarbear ·
Posted in Troubleshooting1 -
4
2
2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
