Is CM Hyper 212 LED TURBO Compatible with CoolerMaster MB500 Cabinet?????
Hi Bros
I am thinking to buy CoolerMaster Hyper 212 LED TURBO Aftermarket cooler for my CoolerMaster MB500 cabinet will it be compatible with it,
As on CM Website The Maximum CPU cooler height supported by MB500 is 160mm
But this cooler is of 163 mm will there be Some Problem ????
CM Hyper 212 LED TURBO-http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-led-turbo/
CM MB500-http://www.coolermaster.com/case/mid-tower/masterbox-mb500/
And how's about CM MB500 opinion in ur view any other better alternatives except s340 elite???
It probably won't fit unless you remove the top decorative plate that adds 3mm of height.
The MB500 has better airflow and the S340 Elite has better dust filters. The psu filter on the MB500 is flimsy like the one on the original S340. 30-CM-MB500.jpg?zoom=2.625&w=290&h=181&s
