Help with compatibility issues?
Go to solution Solved by Guest,
Something like this would be better. The gpu is a bit OTT though for 1080p.
CPU: Intel - Core i7-8700K 3.7 GHz 6-Core Processor  ($369.99 @ Amazon)
CPU Cooler: be quiet! - Dark Rock Pro 4 50.5 CFM CPU Cooler  ($84.99 @ SuperBiiz)
Motherboard: Gigabyte - Z390 AORUS PRO ATX LGA1151 Motherboard  ($184.66 @ OutletPC)
Memory: ADATA - XPG GAMMIX D10 16 GB (2 x 8 GB) DDR4-3000 Memory  ($104.99 @ Newegg)
Storage: Samsung - 860 Evo 1 TB 2.5" Solid State Drive  ($127.96 @ Newegg)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($58.89 @ OutletPC)
Video Card: Gigabyte - GeForce RTX 2080 8 GB GAMING OC Video Card  ($749.99 @ Newegg Business)
Case: Fractal Design - Meshify C TG ATX Mid Tower Case  ($74.99 @ Newegg Business)
Power Supply: Corsair - RMx (2018) 750 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ Newegg)
Total: $1826.45
Generated by PCPartPicker 2018-12-02 16:26 EST-0500
Regarding the compatibility notice, you're fine. It is just a notice telling you that some of the many sata ports will be disabled if you use the M.2. That's normal, and won't be a problem for you.
As for whether or not this is a "good build", I'll let others answer that. I have a policy of not engaging in those discussions. It's tiring. Builds are far too subjective.
Main Rig: R9 5950X @ PBO, RTX 3090, 64 GB DDR4 3666, InWin 101, Full Hardline Watercooling
Server: R7 1700X @ 4.0 GHz, GTX 1080 Ti, 32GB DDR4 3000, Cooler Master NR200P, Full Soft Watercooling
LAN Rig: R5 3600X @ PBO, RTX 2070, 32 GB DDR4 3200, Dan Case A4-SFV V4, 120mm AIO for the CPU
HTPC: i7-7700K @ 4.6 GHz, GTX 1050 Ti, 16 GB DDR4 3200, AliExpress K39, IS-47K Cooler
Router: R3 2200G @ stock, 4GB DDR4 2400, what are cases, stock cooler
I don't have a problem...
11 minutes ago, PowerMasterYT said:
https://pcpartpicker.com/list/fBJCvn
Disregarding price and everything, this is a build i made and i want to actually create it, but i have compatibility issues with data storage (ssd, hard drive), can anyone help?
If you are buying all new, reconsider this build.
9 minutes ago, lee32uk said:
Why are you going with an old cpu ? And why SLI 1070 ti ?
What is the pc for ?
What do you mean old CPU? just because i chose a i7 over a i9 doesn't mean its old?
The pc is based on for running games, at LEAST 60 fps. i'd prefer alot more however due to me constantly running obs and having every setting at high/ultra
This build seriously need to be thought again, old CPU and SLI? yah nah.
Personal Desktop":
Luna, the temporary Desktop:
Agreed. I advise replacing the I7 6700K with a cheaper and much more efficient/ powerful 2700x (plus you get a decent cooler).
Also, replace the 1070's with a single 1080 ti. The rest is highly subjective.
Like I said old cpu. The i7 8700K would be a far better option, or go Ryzen.
alright, it seems i made bad choices then in this. Thanks.
Yeah an 8700K or R7 2700/X etc would be better for gaming/streaming. The 6700K is only a 4 core/8 thread so pretty old hat these days.
What monitor are you going to be using ?
Also what is your budget ? And you in the USA ?
Im using 3 1080p monitors that are all 24 inchs, and yes im in the usa.
Total: $1826.45
Total: $1826.45
Wow, thank you! this looks amazing!
No probs. If your budget is $2400 or so then you could even consider replacing one of the 1080p screens with a 1440p G-Sync for gaming on and have two 1080p either side for web browsing or twitch chat etc.
Monitor: AOC - AG271QG 27.0" 2560x1440 165 Hz Monitor  ($598.90 @ OutletPC)
Total: $598.90
Generated by PCPartPicker 2018-12-02 16:33 EST-0500
