Search In
  • More options...
Find results that contain...
Find results in...
Wifi is dead slow. Ethernet is not.
Megah3rtz
 Share
On my PC(ethernet) I get about 60-80mbps down 10-15 up with 10-15ms depending on the day
On my phone andor laptop it can be slow enough to wait 15seconds just to load the page and then 5-10mbps down and miserable results in the other areas.
Router is a DIR 822 and the wireless adapter version/brands seem to be irrelevant.
I feel like I'm missing something, questions/thoughts?
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
Weak connection? Interference?
How far are you from the router? Are there other wifi networks nearby?
Hello this is tech support, have you tried restarting your devices.
But no serious restart the wireless adapter and router, how far are you away from the wireless signal.
sometimes a reboot of anything can do wonders
CPU:R7 5800X    Motherboard: asrock x470 taichi ultimate   RAM: 32GB G.Skill Ripjaws-V 2X16GB    GPU: Gigabyte GTX1080TI gaming oc 11g   Case: Corsair 600Q Storage: 1TB Samsung 870(boot), samsung 850evo 500GB, 2TB Corsair MX500, samsung 2TB 970 evo plus, WD 5TB black    PSU: Corsair AX860    CPU cooling: Corsair H105
1 minute ago, OBELISKxxx said:
seems too basic but, u tried restarting the router?
yes
sitting next to the router connected to 5GHZ, no other networks nearby.
change your dns to opendns or google (8.8.8.8) open network propery -> adapter property -> change ip4 configurations -> change custom dns to dns1 : 8.8.8.8 dns2 : 8.8.4.4
is the signal at full bar?
when you opened the network interface status, how much is the connection speed?
Ryzen 3600 @ 4.5ghz all cores | Asrock B550M Steel Legend | Radeon RX580 | 2x Samsung 16gb c-die 2666 @ 3600mhz cl16 | 500gb WD SN750 | 9 TB HDD | Deepcool Gammax 400 w/ 2 delta 4000rpm push pull | Antec Neo Eco Zen 500w
DNS is already set to that signal bar is full
Linkspeed to router 433 mbps
so many things can cause issues, its wifi
do you have something to read the signal strength? like a phone or tablet
how many devices are connected? how many of them are wireless?
have tried temp changing the ssid/password and only connecting the device that is having problem?
 have been dealing with a lot of wifi issues lately. if still having issues try unplugging stuff like android boxes or other things.
There are 9 devices connected, 8 are wireless. I will try isolating the problem later today.
can be a pain, try a different channel, is the router on the most current FW
this could be a good LTT video, how to possibly solve your wifi issues.
 Share
