You're not praying enough in its behalf.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1002023-help/#findComment-12024239
We need a substantial bit more info than the nothing you've given us to work off of.
If you have 173 Chrome tabs open, I've found your problem.
If your tentacle-porn "homework" folder is more infested than a whorehouse, there's your problem.
If you're overheating to the point that everything's being thermal throttled to within an inch of not functioning, that may cause an ever so slight decrease in performance.
If you're running a single core system with 512mb of memory, on a 3500RPM drive, I've, once again, found your problem.
If it's all the above, you've just got to throw the whole thing out and start over.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/1002023-help/#findComment-12024289
