Building a pc
Go to solution Solved by orbitalbuzzsaw,
Here you go
PCPartPicker part list: https://pcpartpicker.com/list/MJFDXP
Price breakdown by merchant: https://pcpartpicker.com/list/MJFDXP/by_merchant/
CPU: Intel - Core i7-8700 3.2 GHz 6-Core Processor  ($0.00)
CPU Cooler: ARCTIC - Freezer 33 eSports ONE (Black/White) CPU Cooler  ($31.99 @ Newegg) - It's the best cheap cooler
Motherboard: ASRock - B360 Pro4 ATX LGA1151 Motherboard  ($78.13 @ Amazon) - Cheap and will do its job
Memory: Team - Vulcan 16 GB (2 x 8 GB) DDR4-2400 Memory  ($94.99 @ Newegg) - 16GB of RAM is pretty much necessary for good gaming
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive  ($72.99 @ Amazon) - Best value SSD
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($58.89 @ OutletPC) - Data drive. Does its job fine
Video Card: EVGA - GeForce GTX 1070 8 GB SC GAMING ACX 3.0 Black Edition Video Card  ($0.00) - You already have it
Case: NZXT - H500 (White) ATX Mid Tower Case  ($64.99 @ Amazon) - Cheap and has enough fans
Power Supply: Antec - Earthwatts Gold Pro 550 W 80+ Gold Certified Semi-Modular ATX Power Supply  ($41.00 @ Newegg) - Focus Gold for cheap
Total: $442.98
Generated by PCPartPicker 2018-11-29 14:13 EST-0500
And if you happen to be needing peripherals
PCPartPicker part list: https://pcpartpicker.com/list/p3zVRJ
Price breakdown by merchant: https://pcpartpicker.com/list/p3zVRJ/by_merchant/
Monitor: LG - 29WK600-W 29.0" 2560x1080 60 Hz Monitor  ($229.99 @ B&H)
Keyboard: Cooler Master - MasterKeys Pro M White (MX Brown) Wired Standard Keyboard  ($98.12 @ Amazon)
Mouse: Logitech - G502 Proteus Spectrum Wired Optical Mouse  ($39.99 @ Dell)
Headphones: Corsair - HS50  Headset  ($49.48 @ Amazon)
Total: $417.58
Generated by PCPartPicker 2018-11-29 14:14 EST-0500
Here you go
Total: $442.98
Total: $417.58
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/1001761-building-a-pc/#findComment-12021806
I would start with something similar to this.
PCPartPicker part list: https://pcpartpicker.com/list/KPynFt
Price breakdown by merchant: https://pcpartpicker.com/list/KPynFt/by_merchant/
CPU: Intel - Core i7-8700 3.2 GHz 6-Core Processor  (Purchased For $0.00)
CPU Cooler: be quiet! - Pure Rock Slim 35.14 CFM CPU Cooler  ($28.99 @ SuperBiiz)
Memory: G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory  ($99.99 @ Newegg)
Storage: Patriot - Burst 480 GB 2.5" Solid State Drive  ($59.99 @ Amazon)
Storage: Seagate - Barracuda 3 TB 3.5" 7200RPM Internal Hard Drive  ($74.99 @ Amazon)
Video Card: NVIDIA - GeForce GTX 1070 8 GB Video Card  (Purchased For $0.00)
Case: NZXT - H500 (Black) ATX Mid Tower Case  ($69.99 @ Amazon)
Power Supply: Corsair - CXM 550 W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($29.99 @ Newegg)
Total: $442.07
Generated by PCPartPicker 2018-11-29 14:18 EST-0500
https://linustechtips.com/topic/1001761-building-a-pc/#findComment-12021822
Total: $442.07
That SSD is shite, and you can get a much quieter Freezer 33 eSports One for $3 more!
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
https://linustechtips.com/topic/1001761-building-a-pc/#findComment-12021828
I'll just throw this one on the pile
edit: haha forgot storage, doesn't really matter tho just throw in your favorite ssd
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1001761-building-a-pc/#findComment-12021835
For the record is performs on par with the 860 for less. The biggest different is probably endurance rating, but I haven't checked yet.
https://linustechtips.com/topic/1001761-building-a-pc/#findComment-12021903
30 minutes ago, M.Yurizaki said:
At the minimum:
  • Motherboard
  • RAM
  • Storage drive
  • Power supply
  • Case
The "exact parts" really depends on your needs and what a person feels like.
you can go without a case.
?, you said minimum.
https://linustechtips.com/topic/1001761-building-a-pc/#findComment-12021950
-Thread moved to New Builds and Planning-
https://linustechtips.com/topic/1001761-building-a-pc/#findComment-12022253
