Difference between ducky one tkl rgb and ducky one 2 tkl rgb.
rekt1
HI, I would like to know the difference between these 2 keyboards as i am looking to get either 1 and so i wanna see which is better. Pls feel free to recommend me other tkl keyboards or which of these 2 keyboards i should get thanks
Ducky one has black underside and micro usb. Ducky one 2 has white underside and usb C.
If you're interested in a product please download and read the manual first.
Don't forget to tag or quote in your reply if you want me to know you've answered or have another question.
The Ducky One 2 is the lattest model, released on early 2018, and has better features..
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
ok so which will u take
I use the Ducky One 2 Mini (the 60% size) MX Silent Red switch.
My system specs:
My build logs:
