Usb WiFi
Go to solution Solved by limegorilla,
Well just check to see if it’s present first. Whatever version of Windows your on (although if it is Vista,XP or newer I would strongly advise using it for security reasons) go to the start menu, and if you have search, search for device manager. You will need admin access. The device should be there, but with an exclamation mark next to it.
To answer your question on drivers, It’s most likely that this is an issue rather than hardware failure, but as this computer was not connected to the internet in the first place it doesn’t have tha ability to get any drivers at all - cause it can’t download them. Go to the manufactures website for more information, the model number should be on the dongle somewhere.
Hi guys! Me and my friend are fixing some old compeuters in our school, and we wantet to connect it to internet, so we took a usb wifi adapter from another working pc, and put it in the old compuper but we couldnt connect to internet. So my question is: Do we need to download any drivers¨to get the wifi running? Anyone that can help?
https://linustechtips.com/topic/1001096-usb-wifi/
Bow down to me humans.
I can't help if you don't quote me. How am I supposed to know if you need my premium support? Now starting at £399.99 a year.
Also, be a sport and mark the correct answer as the correct answer. It will help pour souls in the future when they are stuck and need guidance.
"If it works, proceed to take it apart and 'make it work better.' Then cry for help when it breaks." - Me, about five minutes ago when my train of thought wandered.
Remember kids, A janky solution is still a solution.
https://linustechtips.com/topic/1001096-usb-wifi/#findComment-12015744
Because when I connected it, it wouldn't connect to the internet. But can't I just download the driver installer on a USB flash drive, and run the setup on the old computer?
https://linustechtips.com/topic/1001096-usb-wifi/#findComment-12015755
Does the computer detect the dongle?
https://linustechtips.com/topic/1001096-usb-wifi/#findComment-12015759
Yeah, those USB network adapters require drivers which need to be downloaded from the internet, which can't be downloaded if you don't have internet.
Plug the computer into ethernet to connect to the internet, otherwise you will need to manually find the exact drivers for that USB network adapter, put them on a USB using a different computer, then install them from the USB drive.
https://linustechtips.com/topic/1001096-usb-wifi/#findComment-12015764
That was what i was thinking too. Because we don't have an ethernet cable that reaches the pc. Soi could just go on the dongle's website, and download the drivers?
https://linustechtips.com/topic/1001096-usb-wifi/#findComment-12015770
Yeah probably, you just need to find the right one.
I would personally just buy a loner ethernet cable and not deal with USB cards or drivers.
https://linustechtips.com/topic/1001096-usb-wifi/#findComment-12015772
Yeah i know, but this is just a pc that is going to be used like 2/3 days, so we don't want to buy a 100m cat 6 just for ethernet in 2/3 days if i can use the USB Wifi
https://linustechtips.com/topic/1001096-usb-wifi/#findComment-12015782
Yes, some dongles are not plug and play.
It would be better if you just mention the brand / model number.
https://linustechtips.com/topic/1001096-usb-wifi/#findComment-12015867
100m lan cables can buy 3 wifi dongles.
What you can do is, download the right driver in a working pc, copy to usb flash drive and install to the old pc.
https://linustechtips.com/topic/1001096-usb-wifi/#findComment-12015880
