Ideal GPU For 3D Rendering/CAD
Go to solution Solved by FroggyXD,
Just Found my Answer.... Wow lol
Well to start things off I recently built a new system. I still have my old system but I took the graphics card out. I am planning on giving my old Computer to my dad because he does a lot of 3D Rendering and CAD work for his Construction  Business and he is doing it with the Windows Surface 3. My old computer system Build was really just meant for gaming, but I don't see any real reason why It can't be used for 3D Rendering Projects and CAD work. My old Computer has a
Intel i7 6700k Skylake
16GB Corsairs Vengeance Ram
Asus TUF Z270 Mark 2 Motherboard.
Hyper EVO 212 Air Cooler
120GB SSD Sandisk
2TB HDD
Nzxt S340 Elite Case
Was a GTX 1080 TI Gigabyte OC Gaming Black. So my main Question is Would it be fine to use either a GTX 1060 6gb Card or a RX 580 8GB Card? Or should I try and go for a Quadro Card? And if so, Which kind? Anything Helps Thanks.
https://linustechtips.com/topic/1000595-ideal-gpu-for-3d-renderingcad/
Honestly, modern gaming GPUs are so powerful, anything 1050/1050ti+ should work perfectly fine. Looking at 3D models, even complex ones, from many different angles is honestly pretty easy when compared to the stuff gaming GPUs are built for. Sure, the lower you go, the higher the export/render times, but if you're not in a huge rush all the time, the 1060 6gb is a great choice. The extra VRAM and boost to clock speed makes it worth getting over the 3gb model, in my opinion.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
I figured that a gtx 1060 6gb could get the job done. But I am wanting to know how well it gets the job done. I am looking for what will be for the best overall. If card A Will do fine then how well would card B do? I am looking for Not the Quickest Render times because if I want that then I might as well get something like a p6000 and a thread ripper. But I am also not looking for something that will get the job done but drags it feet while doing it.
More CudaCores goes a long way, Which is why I was on my 980Ti for a while cause it had more CudaCores than a 1080, but I went for the 1080 Ti shortly after it launched.
That said any 10 series card 1060 6GB and up will get the job done.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
13 minutes ago, FroggyXD said:
Then how well would a RX 580 Do vs a 1060 6gb?
Short answer, about the same, except it has 2gb more memory and draws more power than the 1060.
https://gpu.userbenchmark.com/Compare/Nvidia-GTX-1060-6GB-vs-AMD-RX-580/3639vs3923
This is, of course, comparing it to the 6gb 1060. The 580 would probably fair better than the 3gb version.
Never rub another man's rhubarb!
4.2225Ghz 1700x on air
cpu-z validation
I would have mentioned the Vega 56, but there's a significant cost difference between that and the 1060. It's more comparable, as Linus said, to a 1070.
Will you be doing more CAD? Or more gaming? Quadros are great workstation cards, but from what I remember, they fall pretty short when it comes to gaming...or at least they used to.
This brings up a curious thought I just had...why not dual monitor, one monitor on a cheap Quadro for CAD, one on a GTX1060 for gaming? Not sure if there would be driver conflicts, but it might be worth looking into.
cpu-z validation
But I think I will be getting either the Vega 56 or the p1000. But I got the answer I was looking for
nVidia's gaming cards have always fallen a little short on CAD use, mostly because it would infringe on the profits of their purpose built Quadros. I don't know much about ATi cards, so I can not give any input on their cards.
cpu-z validation
