AG251FZ problems, can't get 240 Hz
Repput
Hey,
I just bought AOC AG251FZ monitor, for the reason of 240 Hz. The problem is when I try to change the resolution (to the same as standard (1920x1080)) and Hz I just get a black screen and when it turns on again its changes back to (1080p, 1920x1080). When I try to change the resolution through the windows settings, it changes back to 60 Hz, shortly after I hit applied for changing to 240 Hz.
Hope it's all making sense and someone can help me.
  • 1 year later...
hey,my friend,at last ,how did you deal the problom,i meet the same question,i can't get 240hz,too
  • 1 month later...
I found a solution but I can only get to 220hz. I made a costum resolution. For anything above 220hz, the screen goes black for 10 seconds. Hope this helps.
