Need help with monitor.
steve-kon
So I've been thinking of building a budget(ish) PC, with everything falling into place I completely overlooked the monitor. After going through tons of videos on what and how to buy I've decided to buy this,  BenQ XL2411Z. But turns out it doesn't have G-sync. Do I really need a g sync monitor?
The main work i'll be doing is working with 3D models and rendering, editing stuff. But occasionally I would play games too. Those are two different types of things.
Here are my specs:
i5 6600k(I know it's not good for 3D works but the i7 costs a 100 bucks more)
MSI Z170a
GSkill ripjaws V 3200 16gb
750 PSU
I haven't got a graphics card and monitor yet. I'm thinking of getting a 1070.
CPU: Intel Core i5-6600K, Motherboard: MSI Z170A GAMING M5, RAM: G.Skill DDR4 2 x 8GB GPU: MSI GTX 1070 Gaming X, Case: Cooler Master MasterCase 5
Storage: WD Blue 1TB, Samsund 850 EVO 250 GB, PSU: Corsair RM 750X, Display(s): BenQ BL2710PT: Cooling: Thermalright True Spirit 140 Power
Mouse: Gamdias DEMETER II- 3200DPI Gaming Mouse, Operating System: Windows 8.1
1 minute ago, steve-kon said:
budget(ish)
ಠ_ಠ
No but its nice to have for the gaming.
Here are my specs:
MSI Z170a
750 PSU
If you will be doing more creation software then actual gaming G-sync isn't required. Its nice but I have always gamed without it and no issues.
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
24 minutes ago, HydraGaming said:
ಠ_ಠ
lol, it cant be helped though. Call it future((or at least a year or two)) proof. And also GPU rendering is much preferred for 3D renders.
I think i'll just go with a non G Sync monitor. Thanks for the reply.
Here are my specs:
MSI Z170a
750 PSU
You don't need G-Sync, it's just a luxury. Usually I recommend against the XL2411Z though since it doesn't have DisplayPort input. It can only run 144 Hz over Dual-Link DVI, which is falling out of favor (some graphics cards have stopped including it) and you can't get it through adapters.
also active dp to dl dvi are horrible at times
Thank you and I should have mentioned in the post that I don't speak Monitor tech that much. But it has a HDMI input, wouldn't that work?
Can you guys suggest one in the price range of  BenQ XL2411Z  that has a displayport input.
Than you and I should have mentioned in the post that I don't speak Monitor tech that much. But it has a HDMI input, wouldn't that work?
The HDMI port on the XL2411Z doesn't support more than 60 Hz.
How about the ViewSonic XG2401?
Not available in my country and I even tried newegg.com and amazon both show the product as out of stock.
And isn't that freesync monitor, and my graphic card would be an nvidia.
It still works with NVIDiA cards, it would just be like a normal 144 Hz monitor. FreeSync doesn't add any cost to the production of the monitor (which is why it's called FreeSync) so you don't lose any value by not having an AMD card. Just consider it like a regular monitor.
How about the AOC G2460PF?
Sorry but it isn't available in my country either. What about this,
AOC G2460PQU
What about this LG monitor? Can I go for it?
LG 24GM77
