USB Hub with Audio & Ethernet Plugs?
Yali
Is there something like a USB Hub with 10+ Ports, a Headphone Jack and an ethernet port?
-y
99 Kid. Yes. A 'Youngster'.
World famous Couchpotatoe.
not exactly what you search about, but USB Hubs combined with different connectors are called "laptop docking station" (and are really not for docking your laptop in)...
Most of them use proprietary drivers, to have a screen, ethernet aso. signal through USB 3 or USB type c.
Just in case you simply searched for "hubs" and meant that "dockingstations" for laptops. Most of them have exactly all that - DVI/HDMI, some USB Ports and headphone jacks...
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=laptop+docking+station&ignorear=0&N=-1&isNodeId=1
You are allowed to have animated avatars on LTT, but - try to have images like "userbars" in the signature - no chance...
Excels last cell is XFD1048576 and once was IV65536.
(if you want to have the most effective mousepad - use a colored matte floor tile)
