Car Sound System Help
How much are you willing to spend? Are you replacing the head unit too?
You can opt to just replace the front speakers (and leave the factory rear speakers) then fade the sound forward to build a good front stage.
If you won't be playing loud, this is worth looking at for a good entry level build:
JBL GTO Component Set and/or JBL GTO Coaxial
A dash kit and a modern head unit will do wonders to improve your system. The new Pioneer 2-DIN head units have good time alignment, equalization and crossover controls for the price.
Deadening your truck (especially the doors) can be worth it too. Noico mats look pretty good (good reviews and very low price). They're sold by StP (StandartPlast), which is a very good company for noise treatment.
