Scarlet 2i2 USB sound card - Robotic/distorted sound
Solved by Tordal,
I have to say, I'm impressed with Focusrite's support. For those of you with similar problems this might help you on your way:
Hello
Thank you for your email to Focusrite Technical Support UK. Very sorry to hear about your problems, we will do everything we can to get it working for you.
Could you start by optimising your Windows 8 PC for audio by following the steps in the following article:http://global.focusrite.com/answerbase/optimising-your-pc-for-audio-on-windows-8
If you are running the latest drivers (v2.5.1) and you still encounter issues, then it might be worth trying to download the latest beta versions of the drivers from our Beta website. You can download v3.1.8 from here: http://beta.focusrite.com/releases/focusrite_usb2_drivers/
Please read this article to see if it helps at all:
http://global.focusrite.com/answerbase/why-is-my-audio-slowed-down-in-windows-8-when-the-computer-starts
Let me know how you get on.
Thank you again for your email, I look forward to hearing from you.
