I built a 150W 6ch. amplifier in an ATX PSU chassis. Thoughts?
iamdarkyoshi
So I have some leftover parts from when my dad worked for JBL. More specifically, parts from this. I had been using three 50W amplifiers inside of a rackmount high current power supply. I just mounted the face of the transistors to the heatsinks on the side of the chassis and they were always stone cold, passively cooled. After a year of using this, I decided to rebuild it in a far smaller chassis. So I did. @hypnodog sent me an old HP PSU, the kind that is larger than a standard ATX PSU (it uses a 92mm fan instead of an 80mm)
I forgot to take pictures during the build, but I basically have three of these amps mounted to a CPU heatsink, and the CPU heatsink is mounted to the fan. The amp uses 12v AC to power it, the bridge rectifier and capacitor bank are inside the unit. The switch on the top switches the remote signal of the amps, as well as the fan. I get a little bit of hum, but it is nothing major. It is only noticeable with my ear next to the speaker. I want to eventually find a bigger transformer, as a 12W transformer is a little bit... underpowered, thus why I used a bunch of filter capacitors. Still, it went very loud, enough for me to bother the neighbors.
The fan is silent, it moves a gentle breeze over the heatsink and through the amp PCBs. It has 25W per channel.
I am very impressed with how this thing turned out. I do wish I would have shortened the PCB a little bit, as the back is bent outwards a bit. Gain cannot be adjusted without opening the case, so I just use the volume buttons on my keyboard. This is nothing different from the old one.
Picture of the finished amp:
post-128204-0-79109200-1448683043_thumb.
I wanted to paint it red, but I did not have time.
How do you think I did?
are you selling them
CPU: i5 4690k  (overclocked to 4.3ghz)             CPU Cooler: Cryorig h7                 MOBO:  Msi Z97 pc mate             RAM: 8GB HyperX 1600 blue
GPU: rx480  4gb                                                 CASE: Corsair Spec-01 red              OS: Windows 10
PSU: EVGA 500   watt                                       SSD:    v60gb Mushkin ssd                HDD: 1000GB WD BLUE
No, the amps used here are decades old, finding more would be impossible. It took me all day to design and build this. I might make my own from scratch and sell them.
Me likey!
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
Sooo, your test bench has a non covered PSU? 2sp00ky4me
CPU: Intel Core i7 4790K @ 4.6 GHz
Motherboard: Asus ROG Maximus VII Hero
RAM: Corsair Vengeance 32 GB @ 1903 MHz
GPU: Nvidia GeForce GTX Titan X @ 1100 / 7030 MHz
Case: Corsair Obsidian 750D with the Ghetto LED 5000 lighting kit
Storage: 1TB Samsung 840 EVO
PSU: Corsair AX1200i
Display: Dell P2415Q
Cooling: Corsair H100i
Keyboard: Corsair Vengeance K95 RGB (Cherry MX Reds)
Mouse: Sharkk MMO Pro
OS: Windows 10 Pro
Intel Core 2 Quad Q9550
Gigabyte GA-G41MT-S2PT
Arctic Freezer 7 Pro Rev 2
G.Skill Value 8 GB (1333 MHz)
Cooler Master N200
Seagate Barracuda 1 TB
Insignia 300W
Windows 7 Enterprise
Intel Core i3 3240
Asus P8Z77-V LX
4790K stock cooler with Cooler Master HTK-002 thermal paste
Corsair XMS3 4 GB (1333 MHz)
Cooler Master HAF 912
Thermaltake TR2 430W
Windows 10 Pro
I ended up using the chassis and scrapping the PSU board
I guess it stunk too much? lmfao oh well it was 10 years old anyway a cap should have leaked by now
OS: Windows 10 Pro
Cooler Master N200
Insignia 300W
Intel Core i3 3240
Asus P8Z77-V LX
Windows 10 Pro
you guys might like this then
http://spintires.nl/pines/
I have enough other PSUs. Besides, I just bought two 600W evgas for 10 bucks off of their B stock
