Best 4k monitor IPS panel monitor 27inch+
danielhowk
I'm Looking to buy a monitor 27 inch +
4k monitor
IPS panel
60hz or 120hz (if its not too expensive)
G-sync (if possible, if not is fine)
5ms at most
Please give some recommendation. Thank you :)
Asus PG27AQ is 4K GSync with an IPS panel and 60hz refresh rate.
Is there anything more than 27inch + ?
and what about
Acer B326HK is it as good as dell or the asus?
though asus havent released just yet
any other monitor as good as listed ?
thanks in advance
is acer 4k ips model like the b326hk any good? in comparison
Dell P2715Q seems to have 7-9 ms response time , is it really bad for gaming ? semi hardcore gamer here
600$ LG 27mu67 - 27 inch, IPS, 3840x2160, 60hz, freesync
800$ Asus pg27aq - 27inch, IPS, 3840x2160, 60hz, gsync
800$ Acer xb271hk - 27inch, IPS, 3840x2160, 60hz, gsync
1200$ Samsung u32e850r - 32inch, IPS, 3840x2160, 60hz, freesync
asus pg27aq isnt out yet right ? when is the released date?
Acer xb271hk - isnt out yet too right ? when is the released date?
I will have my 27MU67-B next Wednesday let you know then if it is very good or not
