HELP with Fans and Fan Controller?
Solved by dfsdfgfkjsefoiqzemnd,
My former 4870X2 used to run at 92°C all the time on its stock cooler, and the heat coming out the back of that was hot enough to be outright painful.
Still, if you're worried you can always get an aftermarket cooler. Arctic has a whole range, including one particularly suited for the 280X
If it's not the temperature, either your card is defective or perhaps (but very unlikely) isn't getting the correct voltage due to PSU output fluctuations under load.
However my gut feeling tells me that either the card is defective or some parts of it do overheat even if the GPU temps are ok. (a missing thermal patch could cause any individual chip or component to overheat really)
Let me clarify again that the statement above is just a gut feeling.
