Creative Soundblaster ZxR sound card not working
©D0n7H8M3™®
I have a creative sound card ZxR to be exact and I have installed the software my system knows it exists but I am not receiving any sound from it? What could be wrong with it
[spoiler=My Beast Rig Damocles]Case: Coolermaster Storm Stryker Motherboard: Asus x79 deluxe CPU: Intel I7 4960x @3.6GHz (soon to be oc) RAM: Kingston HyperX 64GB @2400MHz GPU: Nvidia Geforce GTX 770 (Gigabyte) @4GB PSU: Corsair RM1000 Fully modular CPUCooler: Corsair H100i Watercooling Storage: Seagate 2TB SV35.6 SATA 6GB/s 7200RPM 64MB 3.5"   x2  Sound: Creative Soundblaster ZxR sound card
This is my old pc which I am reamending to be a media server or a nas. Motherboard: Generic fujitsu CPU: Intel pentium G640 @2.8 GHz RAM: 4GB generic fujitsu memory PSU:  CPUCooler: Stock intel cpu cooler Storage:  Fujitsu MHZ2120BH @120GB, Soon to have a HDD for more storage.
_ASSASSIN_ Jerakl
Right-click the speaker icon in the System Tray and select Playback Devices. Right-click the list of devices and select the option to show disabled devices. Look for the SoundBlaster, make sure it is enabled and set it as the default playback device. Other than that make sure you plugged your speakers into the correct port on the card. Also open the Volume Mixer and make sure you didn't mute the application you are trying to play from. Test with headphones if the speakers aren't working also.
