Thermaltake Riing trio and riing plus rgb fans connected to same board.
Lazaration
Im looking to build my first gaming pc and i have been thinking about using a Thermaltake - Floe Riing RGB 360 TT Premium AIO cooling system. While at the same time use 6 of the new Riing trio rgb fans around the case for general air flow and looks. I plan on using the new Gigabyte z390 auros master board and i have been researching how the TT rgb fans work and have become concerned with potentially not having the different fans work and synch together with the board. Is compatibility and synchrony possible or do all the fans have to be the same???
I would greatly appreciate an answer thank you.
Well you have to check that both the cooler and the fans are compatible with Gugabytes Aorus RGB software (I think that’s the name). If so, then you’re good. If not, then you’ll have to look for an RGB software that they are compatible with, or go third party with a fan controller/RGB header
edit: it looks like they are only compatible with thermaltake’s own in house software
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
