So I recently built my new PC and I've noticed that the cpu is running at the mid 40s when idle. This seems a bit hot if its doing nothing, its a ryzen 2700x and I'm using the corsair h100i pro liquid cooler. My last cpu which was a i5-6500 with a hyper 212 evo idled at the mid 20s low 30s if anyone could give me some advice I'd appreciate that! Thanks
https://linustechtips.com/topic/999849-cpu-running-hot/
What's the temperature under full load?
https://linustechtips.com/topic/999849-cpu-running-hot/#findComment-12004831
It might be a poor mount also Ryzen is not a i5. Remount imo if the temps are unrealistic underload.
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/999849-cpu-running-hot/#findComment-12004848
This probably isn't a cure for your temperature concerns, but have you also set the Minimum Processor State in your selected power plan to anything below 50%?  Anything higher than 50% will prevent the CPU from reaching all its power states.  And you can also use any power plan you'd like if you make the adjustment.  I use 20% and Ultimate Performance.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/999849-cpu-running-hot/#findComment-12004873
I've not got any of my games installed on it or benchmarks so I'm not sure rn its in the mid 50s.
I've not done anything of that sort, how do you do it?
It could be but when I tested the components and it was idling in the mid 30s in the BIOS. Yeah ik my old cpu was an intel i5-6500 and my new one is a ryzen 7 2700x
https://linustechtips.com/topic/999849-cpu-running-hot/#findComment-12004922
When in windows the cpu is never 100% idle as something is always putting a minimal load on it in the background. I would double check CPU voltage in BIOS as they seem to be pretty friggen high with Auto
|King Of The Lost|
https://linustechtips.com/topic/999849-cpu-running-hot/#findComment-12004940
Just checked the BIOS and the voltage was at 1.4, I'm presuming thats quite high??
https://linustechtips.com/topic/999849-cpu-running-hot/#findComment-12004958
Yeah see if you can get it boot and be stable at 1.3-1.35v That seems to be the min voltage for stock clocks.
|King Of The Lost|
https://linustechtips.com/topic/999849-cpu-running-hot/#findComment-12004998
I think my mount is bad, I turned off all fans and the temps stayed the same, I also maxed them out and the pump and still the same temps.
https://linustechtips.com/topic/999849-cpu-running-hot/#findComment-12005008
You don't have to worry about what voltages are running in BIOS.
And to go to Edit Power Plan (you can search it in Windows toolbar) and change the pictured below:
Don't set a static voltage in BIOS.  Use an offset if you feel the need to manage it.  Setting a manual voltage will put the CPU into overclock mode and it won't go through all its power states.
https://linustechtips.com/topic/999849-cpu-running-hot/#findComment-12005009
 Offset or adaptive if its supported ;)
|King Of The Lost|
https://linustechtips.com/topic/999849-cpu-running-hot/#findComment-12005022
Just now, NIGGAS IFFY UH said:
image.png.68dcc0632bc88de9f420e1a025b9a24b.png So think the mount is bad, I changed a load of stuff, fan rpm, pump speed etc and the temps stayed basically the same. The pattern also stayed the same regardless of what I changed
So remount and make certain you use enough thermal paste.
https://linustechtips.com/topic/999849-cpu-running-hot/#findComment-12005029
11 minutes ago, NIGGAS IFFY UH said:
Is that enough paste?
It most likely is.  I prefer using a method like a cross or star to make certain it spreads.  I hate the idea that the entire IHS isn't covered.  It drives me bonkers and makes me remove the cooler and reapply.
Also, is that an ASUS X470 Strix or Crosshair VII board?
Edit:
How does the H100i attach to the stock cooler mount?
https://linustechtips.com/topic/999849-cpu-running-hot/#findComment-12005089
3 minutes ago, NIGGAS IFFY UH said:
Ah yeah I’ve heard of that sort of cross method, I hate messing with the cpu scares me ahaha. And yeah it is that board.
what? lmao He asked which one and you said Yes. Good thing you listed it in your signature though.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/999849-cpu-running-hot/#findComment-12005107
How does the H100i attach via that stock cooler mounting bracket?  I thought it would use the standard Asetek mount.
And you should try out the Performance Enhancer level 3 in the BIOS.  You can use that and then set load line calibration to level 4 and combine that with a negative VCORE offset of around .068V~.075V and be stable.  It will  keep the highest voltages below 1.5V and remain stable.  It isn't necessary, but it's a nice touch.  Also, set SOC to 1.1V.
It's ok, both boards have the feature so yeah.
https://linustechtips.com/topic/999849-cpu-running-hot/#findComment-12005108
That looks like a perfect amount then.  And now I can see how that mount works on the H100i.  I've not seen that before.
https://linustechtips.com/topic/999849-cpu-running-hot/#findComment-12005225
It’s still doing that weird wavelike pattern.. I loaded up cs go and it flattened out in the middle..
https://linustechtips.com/topic/999849-cpu-running-hot/#findComment-12005321
Then it might be the CPU staying within its FIT parameters for PBO.  If temps go up it will reduce speed and when it cools a little it increases speed.  If you use Performance Enhancer Level 3 it is designed to ignore the FIT parameters to a certain degree and will hold a constant all core speed and not throttle/down clock.
https://linustechtips.com/topic/999849-cpu-running-hot/#findComment-12005343
