The fan either is screwed on, but more likely clipped on at the sides or whatever.
You could also just use a bristle to make the dust loose and use compressed air to remove the dust.
As said above, don't breath in dust :P
https://linustechtips.com/topic/999621-help-me/#findComment-12003101
