Hey, first time posting here, but I've been following Linus Tech Tips for a while and I'm finally pulling the trigger on a PC that I'll be building myself.
My budget was about 600€ (I'm from Italy)
r9 270 sapphire 173,15€, I missed some good deals on these unfortunately but oh well, these seem to fly as soon as I turn my eyes off them. Bitcoins...
OCZ PSU 500W 39,92€, they are probably clearing their stock and it's considerably cheaper than other 450W PSUs
CM Elite 120 advanced 42,47€
i54440 158,30€, actually cheaper than the 4430, for some reason
MSI B85M-P33 56,33€, the only part I'm not entirely sure about
Kingston RAM 8GB 1600 74,24€
Kingston 120GB SSD 76,85€, slightly cheaper than the samsung (82,68€), is it worth the extra 6€?
Also I have a 500GB HDD Caviar from my old iMac
What do you guys think? Any red flag?
Edit: I forgot to mention, I'll be doing gaming and light productivity. I realize I could go for an i3 (an I hear Haswell is pretty good) but honestly the i5 wasn't much more expensive so I went with that.
https://linustechtips.com/topic/99934-first-build/
I would go with a AMD processor. Like the 6300k or a 8320/8350 if it fits in the budget. You will get better performance. Also, Welcome
CPU: i7-4770k CPU Cooler: NH-D14 RAM: Crucial Ballistix Sport 8gb GPU: EVGA Superclocked 780 ti MOBO: ASUS Maximus VI Gene PSU: Corsair RM 850 Case: Bitfenix Prodigy M
https://linustechtips.com/topic/99934-first-build/#findComment-1336809
What's the system being used for?
https://linustechtips.com/topic/99934-first-build/#findComment-1336812
I forgot to mention, but I edited the OP since. Mainly gaming.
I noticed you have a matx mobo in a case that only supports itx.
https://linustechtips.com/topic/99934-first-build/#findComment-1336823
Ah, see that's why I need help lol >.> What do you suggest? would this one work for me? http://www.amazon.it/Fractal-Design-Core-Series-Micro/dp/B004ZH18G4/ref=sr_1_1?s=pc&ie=UTF8&qid=1389269550&sr=1-1&keywords=case+micro+atx
Also, since I'm doing gaming, isn't the i5 supposedly quite a bit better since games generally care for single core performance? (at least for now)
https://linustechtips.com/topic/99934-first-build/#findComment-1336835
you won't feel much of a difference between a 8320/50 and an i5... however since the i5 you chose isn't an unlocked processor I'd go for an AMD equivalent so that you can overclock down the line and have extra cores in case they come in handy in the future.
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
https://linustechtips.com/topic/99934-first-build/#findComment-1336848
That works perfectly fine. The i5 is better but going with something like an overclocked 6300 will give you more cores and give you better performance in games that can leverage that while being a bit cheaper which may allow for a better graphics card like a 760.
It depends on what types of games you're playing. Some mmos can be reliant of fast single cores and will be crippled on a 6300 and others will excel.
https://linustechtips.com/topic/99934-first-build/#findComment-1336853
