My Video card will randomly disconnect from my system, when i overclock it.
I´ve got a palit gtx 1080 dual oc with a Raijintek cooler on it.
In my old System it worked fine and everything went smooth, but now it looks like DX12 is killing it.
The error im getting:
https://linustechtips.com/topic/998913-help/
What clock speed did you set it to? And power target?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/998913-help/#findComment-11998231
5 minutes ago, Mephi00 said:
Power full: 120
core: 220
mem: 550
That offset for this card shouldn't be too bad since it's the base model from palit. Did you check temps?
Primary PC:
PSU tier list
https://linustechtips.com/topic/998913-help/#findComment-11998250
65C is max
Thats my latest error:
Is it just BFV with a gsync panel??
Although i had that in GTAV as well, but without an error (just crash)
I´ve already reinstalled the driver after using DDU to get rid of it ?
https://linustechtips.com/topic/998913-help/#findComment-11998253
Battlefield V doenst like overclocks very much at all in my experience, not on GPUs. Try setting your core and memory clocks to +0 and letting GPUBoost 3.0 handle everything for you whilst playing Battlefield V. Leaving your temperature and power limits maxxed won't yield any bad results however.
i7-7700k | GTX 1080 Ti | 32GB 3100MHz | Prime Z270-AR
https://linustechtips.com/topic/998913-help/#findComment-11998390
I dialed back my ocs already and it lasted longer, but still crashes ?.
GTAV didnt crash, so i thought maybe it would work fine now...
My CPU OC is stable, i tested it for 24h w/ prime
https://linustechtips.com/topic/998913-help/#findComment-12000384
still missing about 200MHz and about 5-10 frames
https://linustechtips.com/topic/998913-help/#findComment-12000410
