Graphics Card Upgrade Advice
Go to solution Solved by dbinoj,
Opps. Realised that this is not the section to ask graphics card queries. Created a new thread in Graphics Cards section. http://linustechtips.com/main/topic/100663-graphics-card-upgrade-advice/
I'm marking this as solved so that people do not waste their time trying to help here and instead can help others' queries :) .
I have a Lenovo Machine (7569A19 Similar to this) with Intel G41 Express Chipset.
I need to connect 1 HDMI projector, 1 HDMI TV and 1 monitor.
I will be using triple monitor setup.
Since the projector and TV have only HDMI, I need a video card (which must be available in my market :( ) with 2 HDMIs.
I have selected the Sapphire AMD/ATI FirePro V4800 card.
I have searched and could not find any reliable compatibility guides (Or I'm missing something).
Is this card compatible with my computer?
Edited by dbinoj
Binoj D
https://linustechtips.com/topic/99891-graphics-card-upgrade-advice/
I have a Lenovo Machine (7569A19) with Intel G41 Express Chipset.
No it's not. By the looks of it, your PC is a low profile format and this full-size card probably won't fit in it. You'd best look for a card that has an LP bracket option in it.
Edit: Found this. Not sure if it has an LP bracket but you can Macgyver it in if you're desperate. Just make sure you have enough space for two slots. Also you will need either an adaptor/adaptor cable to go from the second DVI to HDMI. Hope it helps!
MAXIMUS VII HERO | i7 4770K w/ H100i | 2x8GB 1600MHz | GALAX GTX 970 x2
250GB SSD boot | 250GB x2, 1TB SSD storage | Corsair 400C | Corsair RM550
you do not need 2x HDMI ports on a graphics card, just get a graphics card with 2x DVI ports and an HDMI port then get a DVI to HDMI adapter / cable.
CPU: R5 1600 @ 4.2 GHz; GPU: Asus STRIX & Gigabyte g1 GTX 1070 SLI; RAM: 16 GB Corsair vengeance 3200 MHz ; Mobo: Asrock Taichi x470; SSD: 512 gb Samsung 950 Pro Storage: 5x Seagate 2TB drives; 1x 2TB WD PurplePSU: 700 Watt Huntkey; Peripherals: Acer S277HK 4K Monitor; Logitech G502 gaming mouse; Corsair K95 Mechanical keyboard; 5.1 Logitech x530 sound system
 01000010 01101001 01101110 01100001 01110010 01111001 00100000 01100100 01101111 01100101 01110011 01101110 00100111 01110100 00100000 01101101 01100001 01101011 01100101 00100000 01111001 01101111 01110101 00100000 01110000 01110010 01101111 00101110
Thanks for the inputs guys.
Sorry I made a mistake in the original post and linked a wrong product. The lenovo machine I have is from this product line: http://shop.lenovo.com/us/en/desktops/thinkcentre/m-series-towers/m83/ (older version though). It is not a low profile model.
If I can convert DVI to HDMI, what GPU will suite best for me? I need 3 monitors, No fancy gaming. Just HD video playback, presentations, demonstrations, etc.
Binoj D
Binoj D
