Hi, thanks for taking time to read this.
I am pretty new when it comes to custom PCs and hardcore PC gaming. I have built many custom computers for friends and family, but that being said, it's usually someone else who buys the parts, I just assemble them. My current rig was of my own idea, (Not a very good one at that) but being that I had a hand-me-down PSU and 700 dollars, it was great, but now I need something faster, but im not sure how to go upon making it so.
My specs are:
A10-6800k APU
8gb RAM
1tb WD Blue HDD
250gb Seagate (Very old, and yes, it's just a harddrive, not an SSD)
3gb XFX 7950DD Boost (Overclocked to 1100mhz)
MSi E35 A75m FM2 mobo
post-53860-0-11328700-1389246325_thumb.j
Im thinking I need to do something about the CPU and Motherboard. My case is kind of lackluster, being an old Thermaltake from 2004-ish
Thanks in advance
https://linustechtips.com/topic/99879-upgrade-help/
Have a look at a few manufactures Antec ,Cooler Master ,Bitfenix ,Corsair so on .
As the best bet is to start from scratch & get a case . Unless you are willing to do some modding .
Then pick a Socket you want to play on
LGA 1155 is a good cheap way & still powers throw very well (i use it)
So pick a socket always have in mind you're budget ,
Socket type - Mother Board - Cpu to fit that socket ,
then the mother board will have a specific Ram type ,hopefully DDR3 .
@ the end of the day it all boils down to the budget .
Also let us know :
Nvidia or Radeon
AMD or Intel .
Good luck with it all. Get back to us.
Case: | TT Core x71 | Mobo: | Gigabyte Aorus Elite DDR4 | Cpu: 13600K | 1.300V | P-Core 5.6GHZ | E-Core 3.9GHZ | Cpu Block: EK Quantum Velocity2 | Ram: Team T-Force Vulcan Z 4x8GB 3200MHz DDR4 | Gpu: Gigabyte GTX G1 970 Bios Hacked 1.275V | Gpu Block: EK | Cooling: Custom Loop | Rads: 4 | PSU: Corsair RM 1000w
https://linustechtips.com/topic/99879-upgrade-help/#findComment-1336027
Also let us know :
Nvidia or Radeon
AMD or Intel .
Will do. I will be upgrading to an Intel CPU. I'll be back in a while when I can order my new parts and get it all put together. I'll keep the 1155 in mind when picking a new Mobo
https://linustechtips.com/topic/99879-upgrade-help/#findComment-1336056
Don't go 1155 no point, may as well go 1150 as the price isn't much but, I would look at AM3 and get a FX8350 and a 990x board to go with it.
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/99879-upgrade-help/#findComment-1336065
Can you  explain the advantages of going AMD over Intel? From what I see, the benchmarks are better across the board on price comparitave CPU;s
https://linustechtips.com/topic/99879-upgrade-help/#findComment-1336080
The 8350 will pull ahead in games optimized for higher core/thread count (i.e. more of the newer titles)
The i5 will win handily in single core optimized applications and older titles.
8350 wins in sheer multithreaded performance vs i5 while being a cheaper chip and on a cheaper platform. Even then the differences are typically <5fps so w/e.
8350 is cheaper then a 4670k and AM3 tends to be cheaper then 1150
that's what i meant
Error: 410
https://linustechtips.com/topic/99879-upgrade-help/#findComment-1336112
https://linustechtips.com/topic/99879-upgrade-help/#findComment-1336189
Want a faster and snappier system? Get a ssd.
https://linustechtips.com/topic/99879-upgrade-help/#findComment-1350627
