So stable as can be for a weeks, then had to re-do it again stable. BSOD after a week or two of crazy good temps. I know it's cpu related cause the little light on my motherboard turns on and my temps turn to $#@!. So I set it to stock. Temps are still bad. 65c just writing this.
Motherboard problem? Also been running this thing since last year and just recently decides to become unstable. I can fix my re-applying thermal paste and re-doing the OC. I'd have great temps back till it happens again so. here is what the BSOD code is; WHEA UNCORRECTABLE ERROR.
Any ideas what that means or how to solve this issue?
Oh also I'm running a i7 7700K on a EVGA Z170 Classified K with a bios chip for 7th gen cpus.
First watercooled System
Build Name: White Knight
OS: Windows 11 Pro 64-bit
Monitor: Alienware AW3423DWF 1800R Curved Ultrawide 3440x1440 QD-OLED 157hz 10 bit 0.1ms
Chassis: Lian Li 011 Dynamic EVO w/ 2x120mm Corsair QL RGB Fans on the bottom 1x120mm on back exhaust
Top Rad & Fans:  Corsair 54mm 360mm w/ 3x120mm Corsair ML Pro RGB Fans
Side Rad & Fans: Corsair 30mm 360mm w/ 3x120mm Corsair QL RGB Fans
Motherboard: Asrock X670E Steel Legend
CPU: AMD Ryzen 7 7800X3D w/ Corsair XC7 RGB Pro w/ Kyrosheet
Memory/RAM: Corsair Dominator RGB DDR5 2x16GB 32GB 6000Mhz
GPU: Asus GeForce RTX 4080 TUF w/ EK-Quantum Vector2 Nickel/Plexi & Backplate
Pump/Reservoir: Corsair XD5 RGB
Coolant: Corsair Clear
PSU: Lian Li Edge 1000W
Boot/OS SSD: Samsung 970 EVO Plus 500GB NVMe
WZ/2042 SSD: Samsung 850 EVO 250GB
Game SSD: Samsung 980 Pro 1TB
Performance/Editing HDD: Western Digital Black 1TB
Storage HDD: Western Digital Blue 1TB
Mouse: Razer Lancehead Tournament Edition/Razer Mamba
Mouse Mat: Corsair MM700 RGB
Keyboard: Razer Ornata Chroma
Microphone: Beacn Mic
Headset: Razer Blackshark v2 Pro
Eyewear/Glasses: Gunnar Optiks Razer FPS/Gamer Advantage Liquid
Camera: Razer Kiyo Pro/OBSBOT Meet SE
https://linustechtips.com/topic/998556-best-cpu-temps-bsod/
It sounds like a faulty sensor if you've verified good temps but it decides to BSOD then tell you they're bad. What's the crash code?
Edit:
I'm quite familiar with that error code. It means a hardware error has occurred. Usually meaning a physical component has failed. You can try dialing back the OC and see if it helps.
https://linustechtips.com/topic/998556-best-cpu-temps-bsod/#findComment-11995769
Either take up the voltage or take down the voltage and the OC.  If it's not that which I think it is then its your RAM and what not.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/998556-best-cpu-temps-bsod/#findComment-11995865
Quote
@Windows7ge
Edit:
Tested memory says it's fine. dialed back voltage and such when finding stable OC under 5.0ghz. It might be my cooler cause whenever my PC has a BSOD. My coolers tube (where the "wtaer" hit cpu as to cool) is warm to the touch.
Quote
@Turtle Rig
Checked RAm with windows and memtest. Says no errors.
Possible motherboard problem?
There's light under cpu on this board that comes on once it BSODs. Cooler as I said above. Maybe have to RMA both.
Dare I say, possible CPU?!
P.S. Forgot to quote.
https://linustechtips.com/topic/998556-best-cpu-temps-bsod/#findComment-12001942
