q300l fans - SW3 vs A14
Solved by WoodenMarker,
Just now, gordinho said:Thanks so much, completely overlooked the rear was 120mm... since the fans in the front will be behind mesh, should I be looking at p14 instead of the a14?
The NF-P14 is smoother in tone than the NF-A14. Asides from that, the NF-A14 is a slight upgrade across the board over the NF-P14.
They're both excellent and the NF-P14 is the better buy if it's significantly cheaper. Keep in mind that the NF-P14S has a square frame which can be easier to move to a future system over the NF-P14 with a round frame and 120mm mounts.
