Case MAY be too small for GPU
Solved by corrado33,
Quote
- Spacious Interior: The gaming computer chassis doesn't only have a cool appearance but also own a huge room to support up to 380 mm Long VGA card, 160 mm CPU cooler, and 240 mm long water cooling radiator on top and others.
Quote
Item Dimensions L x W x H 8.8 x 4.8 x 1.6 inches
8.8 inches = 232 mm.
You'll be fine.
