low on memory error help
Go to solution Solved by ohJey,
409MB what is it ?
It's space on your hard drive that is used when memory gets low.  I tried disabling it when I got my Samsung SSD but it kept on giving errors.  I was hammering my system just like you (I host a minecraft server, play minecraft, stream music, and stream some video at the same time).  Try setting it to ~4gigs, it should help you out
so when i play battlefield 4 i get this error which says LOW ON MEMORY PLEASE CLOSE THESE PROGRAMS  i don't understand i check my memory and it is only using 6gb or 8gb is there a way to disable this error. it is or so new error because a little wile a go i was able to use all 8gb as seen in the image
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/99788-low-on-memory-error-help/
Low on memory, time to add some more RAM mate and also I'm not sure if you can disable the error message but why would you want to, the problem will still be there.
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
https://linustechtips.com/topic/99788-low-on-memory-error-help/#findComment-1334818
yea i am going to get some more ram but it will have to wait as i just bought a second SSD but as you can see in the image i am able to uses all 8 GB but now i can only us anout 6 1/2
PC PART PICKER
https://linustechtips.com/topic/99788-low-on-memory-error-help/#findComment-1334844
What have you got running?
https://linustechtips.com/topic/99788-low-on-memory-error-help/#findComment-1334854
in this image i am rendering a video in 4k but it normally happens when in BF4 no other games
To be honest I'm not really sure, maybe at 6GB it is close to a system reserve or whatever but not sure, I really need to read into things like this a little more but right now I'm tired and can't think straight (thank you Mr Daniels).
Once you get more RAM you should be fine
https://linustechtips.com/topic/99788-low-on-memory-error-help/#findComment-1334881
409MB what is it ?
Linux "nerd".  If I helped you please like my post and maybe add me as a friend :)  ^_^!
https://linustechtips.com/topic/99788-low-on-memory-error-help/#findComment-1334916
ok thanks i think the error started when i got Samsung Manichean software and optimized it
PC PART PICKER
https://linustechtips.com/topic/99788-low-on-memory-error-help/#findComment-1334934
Pretty much the same thing happened to me, lol
https://linustechtips.com/topic/99788-low-on-memory-error-help/#findComment-1334973
8GB of RAM is plenty, unless he's seriously considering editing video
i just changed it so ill let you no if it happens again
PC PART PICKER
https://linustechtips.com/topic/99788-low-on-memory-error-help/#findComment-1335003
ok thanks for your help that fixed it i done a render with tons of efects and watching a 4k video back at the same time i hit 7.89 GB ram usage and no crash so thanks for your help xD
PC PART PICKER
https://linustechtips.com/topic/99788-low-on-memory-error-help/#findComment-1335085
I moved mine off SSD and onto HDD. Now it won't take unneeded space on SSD.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/99788-low-on-memory-error-help/#findComment-1338631
