Any recommendations for premiere pro spec ideas for £1500 budget?
I was thinking
Gigabyte x470
32gb corsair vengeance ddr4 2666mhz 4x8gb
8gb amd Radeon rx vega 56 / or a gtx 1070 ti 8gb
m.2 256gb for the os and premiere pro
500gb ssd editing drive
2tb seagate barracuda pro
Any ideas? I was going to use pc specialist due to warranty and time
https://linustechtips.com/topic/997719-premiere-pro-build/
I would get 3000 mhz+ ram if possible. ryzen can use it pretty well. what cpu are you choosing? and take a look into first gen treadripper if that fits in your budget. more cores.
A 1080 ti would be nice, but a 1070 ti is enough for that. you could go a little lower on the mobo with a good b450 motherboard. And I recommend 2 lower-end consumer drives in raid over 1 enterprise one.
https://linustechtips.com/topic/997719-premiere-pro-build/#findComment-11989370
If your primary focus is on Adobe application you REALLY should go Intel/nVidia instead, an i7 8700K is probably going to be your best bet, also if you don't plan gaming a GTX 1060 is capable of providing all the CUDA Acceleration Premiere Pro needs, the VEGA 56 would do nothing as Premiere Pro support for OpenCL is non-existing.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/997719-premiere-pro-build/#findComment-11989402
