Best Audio Program(s)
Go to solution Solved by Jogostar,
"Probably Because I'm A Dangerous Sociopath With A Long History Of Violence"
https://linustechtips.com/topic/99704-best-audio-programs/#findComment-1333712
foobar2000
I second this!
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/99704-best-audio-programs/#findComment-1333717
if you want winamp with support, there's always foobar2000.  It's basically the same back end and a very ... uhh... customizable front end.  Grab the columnsUI plugin and it'll make that part easier.
"Pardon my French but this is just about the most ignorant blanket statement I've ever read. And though this is the internet, I'm not even exaggerating."
https://linustechtips.com/topic/99704-best-audio-programs/#findComment-1333723
I use winamp, does anyone know if foobar supports replay gain?
foobar supports everything.  If it doesn't, there's probably a plugin.
https://linustechtips.com/topic/99704-best-audio-programs/#findComment-1334362
Cool. If winamps stop being supported I'll swap over.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
https://linustechtips.com/topic/99704-best-audio-programs/#findComment-1334716
