I'm looking to record gameplay with commentary. I bought Mirillis Action which records my gameplay and voice.
My question is - should I just use action? Or is it best to record gameplay with capture software and record you voice with something like audacity?
https://linustechtips.com/topic/996164-gaming-voice-capture-software-help/
OBS is free, never ever had a problem with it
In general the vast majority of people will use OBS (or nvidia share if you have an nvidia GPU)
OBS is by far the most widely used software and it works fantastic. And its free
Video reviews: https://youtube.com/goldensound and https://www.youtube.com/c/TheHEADPHONEShow Written reviews and measurements: https://goldensound.audio
Current Main Setup: Roon -> HQPlayer -> Holo Audio May KTE DAC-> Holo Serene KTE preamp -> Benchmark AHB2 (Speakers) / Zahl HM1 (Headphones)
Most used headphones: Hifiman Susvara, Abyss 1266 Phi TC, Sennheiser HD800-S, ZMF Atrium
Speakers: Focal Sopra No3 + 2x SVS SB-16 Ultra
It depends what you want to do with it. If you use OBS (or any other free software), you get game and voice audios mixed as single track. If you need to handle those separetly, then you should use something else to give you out that extra audio track. Or pay for extra features of XSplit etc.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
