Search In
  • More options...
Find results that contain...
Find results in...
Why does the fonts look so weird in kde plasma?
Go to solution Solved by MrReaver,
10 minutes ago, wasab said:
Ok, i am running on arch linux with kde plasma as my desktop environment. The theme I am using is the default breeze.
I just noticed that some of the applications do not display properly, particularly in their fonts.
For example, the NetBeans ide looked like this
The fronts look so weird. coding is a complete displeasure in this thing. It isn't this way on other Linux distros I tried. How do I fix this?
try this maybe: System Settings > Fonts > Use Anti-Aliasing: Enabled > Configure > Sub-pixel rendering type: RGB & Hinting: Slight
Sudo make me a sandwich
My PC Specs:
CPU: Intel Core i7 8750H RAM: 16 GB DDR4 2666 MHz GPU: NVIDIA GeForce GTX 1050Ti
thank you!!!!! works like a charm. texts is so much better now
Glad i could help!
My PC Specs:
 Share
