Hi there! This is my first post on the LTT forum, so I apologize for my lack of knowledge of the forum.
Recently, I have taken an interest in being able to remote into my computer from my phone or laptop from anywhere to access files or use the desktop environment. At first, I used Windows Remote Desktop, which worked fine, but accessing it outside of my LAN would mean opening a port that is quite insecure. For this reason, I switched to TeamViewer, which should work fine for my uses.
My PC isn't the most powerful computer (see the spoiler for some specs), but it will pull upwards of 200-300 watts at times, which can be a lot to run 24/7. So, I wanted to be able to start my PC remotely. At first, I thought about doing this externally by just hooking something into my physical power pins on my motherboard, but then I found out about Wake on Lan. I decided that this would be a good idea, and TeamViewer has some other support for Waking outside of your LAN, so I decided this was what I was going to do.
I started with setting up windows, and this was not difficult in the slightest. Then, I switched into my BIOS. This was when things started to become difficult. I found multiple options that sounded like they would support this, but none seemed to work. I sent multiple requests from my phone to start my PC, and I had no luck.
I am aware that it might not be supported on my motherboard, but seeing as I am running the latest bios, I would expect something like Wake on Lan to be there. I'm running a Biostar TA970, with the latest bios from Biostar flashed (97XAD807.BSS).
Here are some barebone specs of my PC:
Motherboard - Biostar TA970
CPU - AMD FX-6300
GPU - Nvidia GeForce GTX 1060 6GB
RAM - HyperX Fury Blue, 4x4GB Configuration
Any help would be much appreciated!
https://linustechtips.com/topic/995417-wake-on-lan-not-working/
Did you initially set up WOL on teamviewer on the target machine before you enabled it in BIOS?
You need to set the WOL feature on the public address.
"either a fixed, static IP through your Internet provider or if your router has a public domain address with the help of a dynamic DNS provider."
https://linustechtips.com/topic/995417-wake-on-lan-not-working/#findComment-11970561
