I am looking to build a PC for 3d modeling and light animation, gaming, and streaming (possibly). I am looking at about $1500 and would like to play at 1080p 144hz. Also, I would prefer matx and I have a mouse and headset (Razer and Logitech respectively) but no keyboard or monitor. I don't exactly know  if this is possible with my budget, but Any help or recommendations are greatly appreciated!
https://linustechtips.com/topic/995209-first-pc-build/
$1500 USD?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/995209-first-pc-build/#findComment-11968505
6 minutes ago, b2c0nb0y25 said:
I am looking to build a PC for 3d modeling and light animation, gaming, and streaming (possibly). I am looking at about $1500 and would like to play at 1080p 144hz. I don't exactly know  if this is possible with my budget, but Any help or recommendations are greatly appreciated!
https://linustechtips.com/topic/995209-first-pc-build/#findComment-11968518
I realized your price point is basically perfect for my PC, so I copied that. I chose an 8700k instead of 8086k since it's more cost effective, and went with 32GB of ram for modelling, but if you think you need only 16GB you can get half to lower the budget. The case is also subjective, I thought it looked cool but it's up to you.
Primary PC:
PSU tier list
https://linustechtips.com/topic/995209-first-pc-build/#findComment-11968570
Thank you, my one possible issue is that I don't have a keyboard or monitor, but I will be a little while before I have the budget anyway, so a bit more saving won't hurt.
https://linustechtips.com/topic/995209-first-pc-build/#findComment-11968612
If that's the case you can save on the immediate expense by getting half the ram and no hard drive, then buy those later. You can user that money for peripherals instead. (also since you're not doing photo or video editing you can go a little cheap on the display.)
Primary PC:
PSU tier list
https://linustechtips.com/topic/995209-first-pc-build/#findComment-11968624
I do have a hdd in my laptop, but I'm not sure if it will work in a desktop, and you make a good point about the ram. Thank you so much!
https://linustechtips.com/topic/995209-first-pc-build/#findComment-11968649
Yeah it'll work. The SATA connector is a standard.
Primary PC:
PSU tier list
https://linustechtips.com/topic/995209-first-pc-build/#findComment-11968660
CPU: Intel - Core i7-8700 3.2 GHz 6-Core Processor  ($308.99 @ Walmart)
CPU Cooler: RAIJINTEK - AIDOS 48.6 CFM Sleeve Bearing CPU Cooler  ($21.34 @ Amazon)
Motherboard: MSI - H370M BAZOOKA Micro ATX LGA1151 Motherboard  ($59.99 @ Newegg)
Memory: Corsair - Vengeance LPX 32 GB (2 x 16 GB) DDR4-2666 Memory  ($219.99 @ Newegg)
Storage: Samsung - 970 Evo 500 GB M.2-2280 Solid State Drive  ($116.99 @ Amazon)
Storage: Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive  ($58.50 @ Amazon)
Video Card: MSI - GeForce GTX 1070 Ti 8 GB DUKE Video Card  ($354.99 @ Newegg)
Case: NZXT - H400 (White) MicroATX Mini Tower Case  ($83.86 @ Newegg)
Power Supply: EVGA - SuperNOVA G2 550 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($49.99 @ B&H)
Monitor: LG - 27UD58-B 27.0" 3840x2160 60 Hz Monitor  ($308.88 @ Amazon)
Keyboard: Gigabyte - FORCE K83 Wired Standard Keyboard  ($39.41 @ Amazon)
Total: $1622.93
Generated by PCPartPicker 2018-11-15 12:16 EST-0500
https://linustechtips.com/topic/995209-first-pc-build/#findComment-11968671
Total: $1622.93
It's pretty good for the non-overclocking route, but 3D software loves ram, so faster DDR4 should be a priority.
Primary PC:
PSU tier list
https://linustechtips.com/topic/995209-first-pc-build/#findComment-11968688
I was looking at an AMD system, partly because it's cheaper (generally) would there be any draw backs by going with a ryzen 7?
No huge drawbacks really, you could get an 8 core CPU and save some cash. It's slower in gaming but for productivity tasks it's usually superior.
It's a great system for modelling.
Primary PC:
PSU tier list
https://linustechtips.com/topic/995209-first-pc-build/#findComment-11968695
How much slower would it be? Would it still be able to support 144hz?
https://linustechtips.com/topic/995209-first-pc-build/#findComment-11968700
since your not ocing and are mostly doing productivity i would instead recommend a ryzen 8 core cpu and no aio this will save a few hundred dollars
with the saved money i was able to
  • upgrade the gpu to a 1070ti
  • upgrade the hdd to 4tb since you said you might be streaming
  • include a monitor(144hz) and mechanical keyboard
https://linustechtips.com/topic/995209-first-pc-build/#findComment-11968701
Thank you, this looks like what I want!
https://linustechtips.com/topic/995209-first-pc-build/#findComment-11968706
