Left computer on streaming a music channel on YT. Took a nap and woke up a couple hours later to my computer on a black screen saying No Operating System found.
Computer on Windows 10 64bit.
CPU: 4770k
8GB DDR3 memory
1060 6gb Zotac Mini
600W PSU
Motherboard: Gigabyte GA-z87-HD3
Not too sure about bios, it says:
BIOS version F4
BIOS date 5/16/2013
BIOS ID: 8A02AG0H
Confirmed boot drive is set as priority in boot order, tried removing the other drives as well.
Was going to give up and just reformat but when I saw it listed in the installation setup page it made me want to try and spend a bit more time to fix it. In the pictures it's listed as Drive 2 partition 2.
Also tried to run the checkdisk command but it says it's unable to run disk checking on this volume because it's write protected.
Any suggestions? It seems like my computer just isn't reading the correct partition on the disk maybe but I'm not sure how to get it to do so.
https://linustechtips.com/topic/995014-operating-system-not-found/
Remove all of your drives except for the boot drive just so you don't get confused on which drive has your Windows installation. You could try repairing the EFI bootloader of your boot drive.
https://www.dell.com/support/article/ca/en/cadhs1/sln300987/how-to-repair-the-efi-bootloader-on-a-gpt-hdd-for-windows-7-8-81-and-10-on-your-dell-pc?lang=en
(The steps apply whether it's a Dell machine or not)
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
Thank you! This looks promising but I'm a little confused/concerned with step  as everything but my removable drive with the Windows installer on it is listed as NTSF instead of FAT32 like it implies. Is that what it wants me to select or is something else wrong?
