Runed the userbenchmark test with this result am i good and my system is running fine?
Solved by Spotty,
Yes, according to that everything is running well. The only issue it is reporting is you have a slow boot drive compared to other users, as you are using a mechanical HDD as your boot drive instead of a faster SSD.
You should look at purchasing a 250GB SSD for your operating system. It will help make your computer feel a lot quicker and more responsive.
