I have acer nitro 5 with i5 8500u and gtx 1050 4gb, recently, my laptop got really loud. Like you would not expect this much of a noise from a laptop. I switched from hdd to ssd and noise went down a little. But recently, as the fan start to spin, it makes so much of a noise i am thinking that my fan might even be broken, at idle for school use, it runs around 2200rpm and it sounds like an airplane. Is that anything I can do about it? I can't send it to the service center because all my classes require laptop
https://linustechtips.com/topic/994135-acer-nitro-5-fan-problem/
Just now, jonrosalia said:
this isn't a new thing on these people find they need to change out the thermal paste for a better one to make the temps to go down also see what the temps are and if you might have to change the fan curve.
temp stays around 40 to 45 C in browsing internet and stuff. But no matter what temp, fan sounds like its scratching against something or missing a screw so its not in a place
ok that's different I would raise the fan temps so they didn't come on until it hit a higher temp
Maybe take it into a repair shop that could tell you what's wrong without taking time away from your laptop.
Could you do a recording?
Might want to RMA since it's new
7 hours ago, DC said:
8500u
BTW, there's no such CPU SKU
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
