Question regarding Corsair Fans and RGB Strips
UnReal_Orbit
Hey guys. I am looking to run the following in my case: (6) LL120 Corsair Fans and (4) of their RGB Strips. If there is any of you that run this setup, or close to it, which of their connection devices (Commander PRO, Lighting Node PRO, etc.) do I need to purchase so I can control all of them at the same time to make them all synced together?
Pretty much run that setup inside, the outside is 4 fans and 6 strips..
easiest just to get
2 x 3 fan kits  ( 6 fans)
1 x strip kit   ( 4 strips)
This will give you  2 x lighting node pro's and 2 x fan hubs.   (1 spare hub)
The great thing about this is you can control the strips separate to the fans or sync them all using link.
