I'm looking to finally upgrade my ageing GTX 960 2GB and I'm not sure what to do. If I upgrade for Christmas then for my budget (max about £350) then I'm looking at a GTX 1070.
My question is this. Do I go for the 1070 for Christmas or do I stick it out and see what the GTX 2060 is like for price and performance? Is the 1070 likely to drop in price when the 2060 comes out? Will a 1070 last 3-5 years without bottlenecking hard (I'm at 1080p60 with a Ryzen 5 1600, not planning to increase resolution any time soon).
|| CPU: AMD Ryzen 5 1600 (@3.9GHz) || Motherboard: ASUS Prime B350 Plus || Cooler: Arctic Freezer 33 eSports Edition || GPU: EVGA GTX 1070 SC || Memory: 16GB G.Skill Trident Z RGB C16 (@2933MHz) || SSD: SanDisk 128GB || HDD: WD Blue 2TB, Toshiba 2TB, Transcend 1TB || PSU: Corsair RM550x || Case: Fractal Design Focus G || Monitor: 2x AOC 23” I2369VM IPS Full HD, Samsung 32" LED TV Monitor || Mouse: Logitech G703 Wireless || Keyboard: Cooler Master MK750 RGB (Cherry MX Brown) || Speakers: Dell Stereo Speakers || Headphones: Sennheiser HD 4.40 BT / Samsung Galaxy Buds ||
https://linustechtips.com/topic/993927-gpu-help/
GPUs and CPUs rarely drop in price. They usually just run out of stock and disappear. There's also no information on a GTX2060 yet, so there's no way to know how it'll perform. That said, it will cost more than a 1070, that much we know, so it might not even be worth it.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
https://linustechtips.com/topic/993927-gpu-help/#findComment-11957129
4 hours ago, voiha said:
Will 1070 last 3-5 years, yes it won't disintegrate, will it be able to run every game on 60fps+ well....Look at GTX 770 and how it is performing, it should be similar.
I mean yeah the 770 isn't doing as great as it used to but the 970 is only a year younger and still kicks decent ass at 1080p. It only lags about 10FPS behind the 1060 in Shadow of the Tomb Raider so if the 1070 is doing that well in a few years I'd be happy. I'm pretty sold on going with Pascal at this point given the price of the 20 series although I may look at a used 1070Ti although that does mean having to avoid mining cards.
https://linustechtips.com/topic/993927-gpu-help/#findComment-11958063
Yeah I think I'm gonna go with a 1070 or 1070Ti depending on deals or the used market.
https://linustechtips.com/topic/993927-gpu-help/#findComment-11958077
